LabVIEW 2011 and wes7
Is LabVIEW fully supported in WES7 (Windows Embedded Standard 7 Standard). Windows is becoming a huge support/maintenance problem for us. I would like to use WES7 instead of Windows to improve stability, ease of installation, less crapware (from windows and our IS department). If anyone has used it, what are some of the downsides to it?
(3,787 Views)
Here is a document describing our support for Windows Embedded 7. If you are using some of the supported hardware then yes we can help but if you are installing it on other hardware then it will be extremely difficult to help. Just want to make sure you saw this.
http://zone.ni.com/devzone/cda/tut/p/id/13048
Kyle Hartley
Senior Embedded Software Engineer
(3,730 Views)
So, there is a wes7 build that NI uses they feel comfortable with in these computers. Is this information available as to how it is configured?
(3,718 Views)
As far as I know Ni does not officially support LabVIEW on wes7.
Having said that there is some documentation about using LV with wes7 on our RIO platform.  Since that is the case I do not see why you would not be able to use it, but we cannot guarantee it would have complete functionality, there just isn't enough documentation on it.
Eric L.
Applications Engineering Specialist
(3,701 Views)
