‎12-10-2011 02:31 PM
Is LabVIEW fully supported in WES7 (Windows Embedded Standard 7 Standard). Windows is becoming a huge support/maintenance problem for us. I would like to use WES7 instead of Windows to improve stability, ease of installation, less crapware (from windows and our IS department). If anyone has used it, what are some of the downsides to it?
‎12-13-2011
02:19 PM
- last edited on
‎07-21-2026
10:15 AM
by
Content Cleaner
Here is a document describing our support for Windows Embedded 7. If you are using some of the supported hardware then yes we can help but if you are installing it on other hardware then it will be extremely difficult to help. Just want to make sure you saw this.
http://zone.ni.com/devzone/cda/tut/p/id/13048
‎12-14-2011 08:19 AM
So, there is a wes7 build that NI uses they feel comfortable with in these computers. Is this information available as to how it is configured?
‎12-14-2011 02:15 PM
As far as I know Ni does not officially support LabVIEW on wes7.
Having said that there is some documentation about using LV with wes7 on our RIO platform. Since that is the case I do not see why you would not be able to use it, but we cannot guarantee it would have complete functionality, there just isn't enough documentation on it.
