LabVIEW 2011 compiled application icon missing
Troy,
I have not tried this in XP SP3 yet. Please give me some time to get ahold of a test machine to try this.
Is anyone else experiencing this problem in SP3 or can try to recreate the issue?
Joel C
Message 11 of 13
(1,529 Views)
Accepted by TroyK
Are you using the ini token lazyLoadIcons=True?  This was added in LabVIEW 2011 f2 and later to fix an issue described in the this KnowledgeBase.  If you do have that token enabled you will need to turn it off and rebuild or add additional tokens as described in the KB.
If you aren't using this then working with the AE to reproduce the problem will be most beneficial.  The icons are saved within the VI files themselves so this shouldn't have anything to do with the RTE.  If the icons are showing up in the exe on machine I wouldn't expect them to show up on any machine.
Jon S.
LabVIEW NXG Product Owner
Message 12 of 13
(1,514 Views)
Jon_S wrote: Are you using the ini token lazyLoadIcons=True?
Yep, that was it. Thanks.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 13 of 13
(1,507 Views)
