LabVIEW 2011 x64 & Add-Ons ???
Sam,
These are wonderfull news and info for me, because I use Keil MCB2370. Can you confir I have understood correctly - there is APSOLUTELY NO problem in compiling using the Keil toolchain and deploying to MCB2370 within the LabVIEW 2011 Embedded for ARM on LV 32-bit on WIndows7 64bit?
Thanks in advance!
Message 11 of 12
(483 Views)
Golubovski,
You are correct.  The only issue that you may encounter as a result of using LabVIEW Embedded for ARM 2011 32-bit on Windows 7 64-bit OS is that the EK-LM3S8962 USB target will not work by default (I hope to have a work around for this shortly).
You should not experience any problems compiling or deploying due to the 64-bit operating system.
Again, I'm sorry for any confusion.  Let us know if you have any additional quesitons.
-Sam K
LabVIEW Embedded Product Support Engineer
National Instruments R&D
Message 12 of 12
(476 Views)
