LabVIEW 2014 cannot find FPGA target "PXI-7813R"
Hey,
I want to create a new “NI VeriStand FPGA Project” in LabVIEW 2014 with the project type “R Series Multifunction RIO on Real-Time PXI”. The Real-Time PXI Remote Controller “PXI8115” is identified, but in the next step he cannot find a FPGA Target (actually: PXI-7813R).
In LabVIEW 2013 it works fine and on another PC with another hardware (but the same manufacturer and modules) it also works fine in LabVIEW 2014.
If I want to add the target in a blank project, the PXI-7813R isn’t shown in the window “Add Targets and Devices on My Computer” on “New target or device”.
So I thought it isn’t installed. But the “NI R Series Multifunction RIO User Manual” describes the “Real-Time Module” as necessary and this module is installed (as you can see in the screenshots of NI MAX).
On the PC is also installed the “NI R Series Multifunction RIO 14.0” and the “NI-RIO 14.5”.
Hardware:           PXI-1042 with the controller PXI-8115 and the FPGA target PXI-7813R
Operating system:           Windows 7 64-bit
Screenshots SW:
PC:
PXI:
Best Regards,
SysCra
(4,038 Views)
Hi SysCra,
Installing NI R Series Multifunction RIO 14.0
Complete the following steps to install NI R Series Multifunction RIO 14.0 for use with LabVIEW.
    Install one of the following supported versions of LabVIEW:
        LabVIEW 2014
        LabVIEW 2013 SP1
        LabVIEW 2012 SP1
        LabVIEW 2011 SP1
    Install LabVIEW Real-Time.
    Install LabVIEW FPGA.
    Install NI R Series Multifunction RIO 14.0 using the installation media or NI Driver media.
I've just had a look to the readme of the NI R Series Multifunction RIO 14.0 Readme. Seems like LabVIEW 2014 SP1 is not yet supported. Please update to a newer version.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,978 Views)
Hey Christoph,
thank you very much for your answer.
I didn't think that I have to pay attention to such details...
Best Regards,
SysCra
(3,967 Views)
