LabVIEW 2015 RTE on Windows 7 Embedded fails to load (system error 998)
I have a small test application written in LV 2015 that I am trying to get to work on a panel PC with Windows 7 Embedded. I made an installer that installs the run time engine and my program. The install goes fine but when I try to run my program I get "System error 998 while loading the LabVIEW Run-Time Engine C:\Program files\[...]\lvrt.dll"
Is there anyway I can get this to work on Windows 7 Embedded or does LabVIEW just not work with it?
Message 1 of 9
(4,972 Views)
The only weirdness I am doing is disabling SSE2 optimization because the target doesn't support it. Any help would be appreciated.
Message 2 of 9
(4,935 Views)
Did you restart after installing the run-time engine?  I've seen times when I ignored that step and the program would run, partially, or act weird until a restart.
Can you run any programs?  Try making a hello world or some kind of test that isn't your whole application and see if that runs.
Message 3 of 9
(4,926 Views)
Yes I restarted and this program is basically hello world. There are just a couple vis that are mock up screens of my application. I also tried uninstalling all NI software and installing the run time engine by itself then my application but always the same error.
Message 4 of 9
(4,919 Views)
I have successfully used WES7 PC's (from several different vendors) using LabVIEW 2011 SP1. Doesn't help you with 2015 other than showing it has run on previous versions.
Message 5 of 9
(4,902 Views)
Everything I have read indicates that LabVIEW should work on WES7 providing the right packages are installed, but I don't know what those packages are. I don't suppose you remember which packages were installed for Windows?
Message 6 of 9
(4,855 Views)
Hi StevenD,
I have a question. Was the application developed in Windows 7? If not, this might be the issue.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MeUSAU&l=en-US
-Enhernan
Message 7 of 9
(4,834 Views)
It was not. It was done in Windows 10. I got ahold of a Windows 7 machine and tried to make an installer from that machine instead but I am still having the same issue, the run time engine fails to load.
Message 8 of 9
(4,826 Views)
Before running the installer on the W7S. Were you able to run it in the Windows 7 machine? Have you tried in other Windows 7 machines?
Message 9 of 9
(4,818 Views)
