Reading column lengths from an array
I have a spread sheet of one column that gets updated with a new random number every time a button is pushed, and a second column that is has a separate number that the first random number is assigned to.
I am trying to read the column lengths of each of these columns so I can more quickly find where the next random number needs to be assigned. I assume that as long as the column lengths aren't equal, there is an unassigned 2nd column number. Before, I was going row by row in a while loop looking for the first blank space in the first column (also indicating that there is a unassigned second column number) and using that iteration number as the length. However, the spreadsheet I'm reading from is fairly long, so that method took around 35 seconds which I am now trying to optimize.
I feel like this is something really really easy and I am just having a brain fart of sorts. I have tried several different things, but my probes keep saying that they are reading the same number of lines. I have attached a screenshot of this section of the code. Any help would be awesome!
(2,999 Views)
Accepted by topic author notAWizard0555
Hi not,
In a 2D array all columns have the same length!
What about using Search1DArray to search for "blank" elements?
(2,994 Views)
Ohhhhhh. Yep that would make sense. The search 1D array could also be something I could do, but I'm concerned that would also take quite a bit of time. I'll test it out!
(2,990 Views)
You have a formatted text string and once you scan it as DBL, "blank field" no longer has any meaning (it will be padded with zeroes to the longest row/column as defined by the max number of  row and column delimiters in the string).
A better bet would be to convert it to a string array (usign the same tool, but with type = 2D array of strings!) and search for empty strings.
Still that entire thing does not make a lot of sense. Where does the string originate? Do you mean some columns don't have an second assigned value? How can that even happen?
(2,959 Views)
