LabVIEW 2015 not installing, autorun.exe 'encountered an improper argument'
OK, and did you try running the setup.exe, instead of autorun.exe?
Message 11 of 14
(1,837 Views)
Yes I did; please read the first post (regarding the problem) in this thread. It has most of the details you would want.
Message 12 of 14
(1,833 Views)
Ah, sorry, I read it but somehow skipped that sentence...
I am running out of ideas, but these are the things I would try:
- run a registry/installation cleanup utility (I can't recommend one, but Google will help you)
- install some driver/tool from NI that doesn't require LabVIEW (for example NI System Configuration) and then try with LabVIEW again
- use Windows backup to restore your computer to the state from before the reboot (provided that you had Windows Restore enabled)
Message 13 of 14
(1,822 Views)
Accepted by Shlok1229
If it is Windows 7+, perhaps check C:\ProgramData\National Instruments.  (ProgramData is a hidden directory, so you will need to set folders to view it.  I'd not delete it, but perhaps change its name.)
Jon D
Certified LabVIEW Developer.
Message 14 of 14
(1,806 Views)
