LabVIEW 2016 FPGA local Compiler issue
LabVIEW 2016 (32-bit) local FPGA compiler does not complete the compilation process and stops at the “finalizing programming file” step with a message “MS Visual C++ 2012 Redistributable (X64)-11.0.60610 modify setup” (figure 1) which offers repair, uninstall or close the program. However, running the repair option with successful result does not fix the problem of local compiler issue (figure 2).  Figure 3, incomplete compilation with the Xilinx options setup and elapsed time high-lighted.
Any help/suggestion is greatly appreciated.
Mike.
System setup;
Windows 10 Pro
Device: NI cRIO-9066
LabVIEW 2016 Professional Development System
Compilation Tool: Xilinx Vivado 2015.4
(2,343 Views)
Accepted by MikeNasab
Hi Mike,
There's an NI KB talking about this exact behavior. Can you try the steps listed in the article?
Visual C++ Version Redistributable Pop-Up When Compiling LabVIEW FPGA Code
(2,304 Views)
Hi elcalverado,
Thank you for providing the solution, option C “edit the system environment variables” took care of the problem.
Mike.
(2,276 Views)
