LabVIEW 2017 (32-bits) compatibility
Hi everybody,
I'm new using Labview and I'd like to know if there is an incompatibility between the LabVIEW 2017 (32-bits) and a cRIO-9104 with the specifications shown in the photograph.
Thanks for the help.
(2,472 Views)
Looking at the search tool here: https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio...
I'd say you're fine - LabVIEW 2017's FPGA module has an accepted compiler for the cRIO-910x devices.
Contrast that with the result when selecting 2019...
(2,468 Views)
