LabVIEW 2019 Invalid App Kind
I use the AppKind property (App property node) in lots of my programs to either exit or not depending on whether the program is running in the development system or compiled exe.
I just upgraded from LV2017 to LV2019 and the App.Kind property returns "Invalid app kind" for the LabVIEW 2019 development system!
=== Engineer Ambiguously ===
Message 1 of 17
(5,615 Views)
Don't have 2019 to test, but what happens is you delete the open reference in your VI. Just use the property node App Kind, you should not need the Open in front of it. Maybe it is passing an invalid reference.
mcduff
Message 2 of 17
(5,592 Views)
Same thing... I think I found a bug!
BTW: The first post was a chunk out of a VI I wrote over a decade ago when I was pretty green... I used to always put things like the Open and Close in my VI's "just because". I am a little more lazy about it these days
Message 3 of 17
(5,584 Views)
Just guessing here, because that property is used everywhere and if something was wrong with it, I am surprised that it hasn't been reported before.
I would suggest exiting and restarting LabVIEW and see if the error persists, if so, you may have found a bug.
mcduff
Message 4 of 17
(5,576 Views)
mcduff
My first and second post are from TWO DIFFERENT installations on two different computers!
I might have a third station with 2019 Development System installed
Message 5 of 17
(5,573 Views)
I just tried this in LabVIEW 2019, and I get the "Development System" return from the App.Kind Property Node.
Message 6 of 17
(5,569 Views)
Here's a new twist
On two out of three systems it returns "invalid app kind" but on the third it returns "Development System"
All three are Version 19.0f2
I don't know what to think...
Message 7 of 17
(5,546 Views)
While it doesn't address the problem with the node your system in particular seem to be having, have you considered using a Conditional Disable Structure with the RUN_TIME_ENGINE condition?  That reduces your options to two discrete ones, instead of 6 valid options and 1 invalid option.
Message 8 of 17
(5,540 Views)
Data point: My Windows 7 Virtual Machine with version 19.0f2 32 bit LabVIEW - returns "Development System".
Possible clue - "invalid app kind" is the default value. Have you probed the wire?
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 9 of 17
(5,539 Views)
@RTSLVU wrote:
Here's a new twist
steve
The only difference between these three systems is the one that returns "Development System" is running Windows 7 and the other two that return "invalid" are running Windows 10
Message 10 of 17
(5,527 Views)
