Save all data from runtime controls and graphs which can be reloaded.
I think an important function specially for tests that can take a long time to run:
Let us assume a user needs to quit a program and continue the next day or there is a power cut.
Is there a straightforward way to save completely all operations and data currently being run at runtime and reload them as if the program was never closed?
=> data from controls and graphs etc?
(2,465 Views)
Accepted by topic author rajiv85
Hi rajiv,
Yes, there is: you need to log all user actions/settings in a logfile/configuration file.
Load those files at startup of your program and use the saved values from these files…
(2,455 Views)
Thank you very much for confirming!
(2,451 Views)
