LabVIEW 2019 f2 launching slow
Hello community,
I am using LabVIEW 19.0f2 (64-bit). Recently, my LabVIEW launched very slow. It hangs at "Finishing Initializing" screen for around 50 seconds then go to the welcome screen.
I thought it might be some other software conflicts, thus I made a fresh install of Windows 10. However, the issue still exists. The issue makes LabVIEWCLI operations and VI Package Manager package installations sometimes timeout.
Any thoughts on this issue?🙄
Thanks.
Message 1 of 10
(4,469 Views)
Hi Alan,
I noticed that this is the point where LabVIEW verifies that it is licensed. And depending on the way you activated LabVIEW, it might need to reach the network. If you are using a Volume License Manager, it will try to reach the server where your licenses are managed and that might take a while if your internal network is slow. How did you activated LabVIEW?
Guillermo Oviedo
R&D Software Engineer
CLA | CTD
Message 2 of 10
(4,392 Views)
Hi Guillermo,
I am using local licenses. So I think it might not be a license issue?
Local LicenseLocal License
Network LicenseNetwork License
Message 3 of 10
(4,362 Views)
The first image (in the first post) does say "Unregistered".
That doesn't seem right... It should list name, company, serial nr., license type (this is listed).
I'd try unregistering, re-registering, reactivating, and such...
Message 4 of 10
(4,340 Views)
The Professional version is Licensed.
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 10
(4,330 Views)
I've had similar issues before, and there are several threads about it, so to cross something off the list, unplug the network cable and then launch LV and see if it goes faster.
/Y
Qestit Systems
Message 6 of 10
(4,327 Views)
Not according to the splash screen.
Message 7 of 10
(4,326 Views)
Hi Alan,
It seems that also the communication with a remote VISA device could be slowing down your startup according to the following KB LabVIEW Taking a Long Time to Launch , I would give it a try with the suggested solutions.
Cheers.
Guillermo Oviedo
CLA | CTD
Message 8 of 10
(4,287 Views)
Hi Guillermo, Yameda
Thanks for your reply. I've tried these two solutions from NI KB, but the issue still persists.
Below is regarding license and remote VISA resources.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OhzSAE&l=zh-TW
Another one is regarding LabVIEW.ini file.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DdQISA0&l=zh-TW
Message 9 of 10
(4,235 Views)
Accepted by topic author alan0428a
Hey guys, I think I found the cause of the issue. It's my Type-C hub🙄. My hub has a HDMI port, 2 USB 3.0 port, SD-card reader, RJ45, and type-c power in port. I don't know why LabVIEW is not compatible with this type-c hub. (I have another type-c hub, but has no issue with LabVIEW).
I confirm the cause by the following procedure:
1. Unplug type-c hub, launch LabVIEW several times. It works smoothly.
2. Plug type-c hub, launch LabVIEW. LabVIEW hangs at the splash screen.
3. Unplug type-c hub. LabVIEW goes to the welcome screen immediately.
I've tried the procedure several times. So I think it's no coincidence. So weird.
Message 10 of 10
(4,204 Views)
