LabVIEW 2020 Community Edition Installation Error
When I attempt to install the LabVIEW 2020 Community Edition I get Error '3' occurred while trying to copy the file 'C:\Users\...\AppData\Local\Temp\7zOC554E626\bin\nipkg.ini' to 'C:\Users\...\AppData\Local\Temp\nipkg_preinstall-b77e-b230-1b2e-4989\nipkg.ini'. Error details: The system cannot find the path specified. Indeed, there is no such .ini file at the location from which the copy is being attempted. What do I need to do to solve this problem?
Message 1 of 9
(6,392 Views)
  • Is your disk very full?
  • How big is the ...\AppData\Local\Temp folder?
  • Do you run any unusual antivirus or security software?
  • Where did you download the community edition from?
  • What is your OS version?
  • Did you scan the HD for errors?
  • How about a disk cleanup?
  • What kind of privileges do you have?
Message 2 of 9
(6,383 Views)
Thank you for offering to help. Here are the answers to your questions:
  • Is your disk very full? no, 375 GB available
  • How big is the ...\AppData\Local\Temp folder? 694 MB
  • Do you run any unusual antivirus or security software? No, I have recently successfully installed LabVIEW 2019 with trial license (that has now expired)
  • Where did you download the community edition from? https://www.ni.com/en-us/shop/labview/select-edition/labview-community-edition.html
  • What is your OS version? 10 Pro
  • Did you scan the HD for errors? Yes
  • How about a disk cleanup? Yes
  • What kind of privileges do you have? Administrator
Message 3 of 9
(6,375 Views)
Accepted by topic author jimu20
Well, I am almost out of ideas....
  • The distribution is an ISO file. Do you have any third party disk burning software that opens iso files by default (instead of windows explorer)?
  • You could try extracting the ISO to a folder (e.g. using 7zip) and run the installer from there. Not sure if it would make a difference.
  • How big is the iso file? Are you sure it downloaded completely?
Message 4 of 9
(6,353 Views)
This worked. I now realize that when I selected the ISO file it was opening in 7zip and I was trying to run install.exe from there before extracting the contents. Once I extracted the contents and ran from the extracted location it worked.
Thank you!
Message 5 of 9
(6,333 Views)
I used software that mounts an ISO image as a virtual CD/DVD image and that worked fine.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(6,323 Views)
Windows 10 mounts ISOs automatically when double-clicked. No software needed. (Of course if certain third party CD burning software is installed, it might squat on this feature, potentially breaking other things. :()
Message 7 of 9
(6,317 Views)
I haven't upgraded to Windows 10.  (At home.)
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(6,301 Views)
Yes, I remember these times. 😉
Message 9 of 9
(6,296 Views)
