LabVIEW 2021 Cannot Save Word Document from Report (But can create excel or HTML)
I have a c:\temp directory on my computer.  I'm trying to run the dirt simple VI which creates a report (either Word, Excel, or HTML).  When I run it as a "Word", a save prompt comes up.  Yes, I can type the path and filename at the prompt and it does save, but that is not how the program is supposed to work.  In addition to this, I get an error code (-2146824090)
Exception occured in Microsoft Word: Command failedHelp Path is wdmain11.chm and context 36966 in NI_ReportGenerationToolkit.lvlib:Word_Save_Document.vi->NI_Word.lvclass:Save Report to File.vi->CreateAndSaveReport.vi
When I run the VI as Excel or HTML, the file gets created perfectly.
(876 Views)
The program is failing at the first RGT function, Create Report.  I've not used the RGT with Word recently, so I'm uncertain how to fix this bug.  I can tell you that it happens right at the tail end of NI_Word.lvclass:Create Report.vi, when it calls a sub-VI called NI_Word.lvclass:new report subVI.  The very first thing that happens in there is LabVIEW tries to execute an Automation Open function with argument Word._Application and a string "machine name (empty)" (which I think is, in fact, an empty string).  This spits out a long Error number, which kills everything "downstream".
(841 Views)
I have 2018 and the code works fine after I recreated your VI.
From 2018, here is the section of code in the VI that Bob is referring to.
Maybe the Word._Application needs to be relinked to the ActiveX object?
Have you checked the RGT Toolkit's compatibility with your Office and Windows version?
It's strange that it works for Excel but not Word.
Have you opened Word separately from LabVIEW? If this is a fresh install of Office, a dialog could be blocking the execution of your program.
aputman
(824 Views)
I'm having the same issue. Word opens the template, and then hangs waiting for the user to specify the location to save the document, which is set to a default name and directory and not the temp path below.
Clark1654375_1-1744240359847.png error -2146824090
Digging a couple layers in to Word_Save_Document.vi it fails here:
I've turned off 'autosave to cloud' and enabled 'save to computer by default' in word save options thinking that might be the problem, but no luck.
I don't see any pop-ups in word that would otherwise block this function.
Any thoughts?
(680 Views)
Please clarify what this means.  The VI returns an error if a path/filename is not provided.
aputman
(646 Views)
