LabVIEW 2023 Q3 - DAQ Assistant Error
When trying build a DAQ Assistant on the Block Diagram (Selecting a DAQ Simulation from the MAX App),
an Error occurred after the Initialization event (which included a "Selecting the Measurement Type for the Task" window including a Generate Signals, Analog Output, Voltage, NI myDAQ, ao0 action on our part).
" LabVIEW Code Generation failed to execute. This may occur if the code gen engine is not properly installed, or if you are using a LabVIEW version under development."
How can we fix this problem?
Thank you,
Jeff Reynolds
Macomb Community College - LabVIEW Academy
(1,047 Views)
Here is the bug note for it, and the workarounds. Simplest solution seems to be to install DAQmx 2024 Q1.
(994 Views)
Applying the DAQmx 2024 Q1 fixed the problem. Thank you
(940 Views)
