LabVIEW 2024 Q1 problem with exe. file even it works well in LabVIEW Professional Development system
Hi all,
I have program written in LabVIEW Professional Development System 32bit, 2024 Q1 on a Windows 11 Pro.
Program runs well in the LabVIEW environment and when I created the .exe file, it shows error as in the attachments.
I created two releases of the software with LabVIEW 2023 Q3 last year and everything was working well.
Does any body can give a hand? Thanks.
(518 Views)
I have seen that. I have not had the problem for some time now, likely due to upgrading to 2024Q3 and/or a patch that came through. The first item listed in the 2024Q3 Bug Fix list seems like the relevant fix.
GCentral
(501 Views)
wow, thanks for your fast reply. I will ask NI if they can provide me the updated version 😞
(498 Views)
Accepted by topic author Nguyen_GaNSensors
Use NIPM. There is a tab for "updates" that will tell you if there are patches for packages you have installed. You can also use the product browser to install a version of LabVIEW you want. If you have an up-to-date license, you can just install LabVIEW 2024Q3 through NIPM.
GCentral
(491 Views)
Indeed I could install the LabVIEW 2024 Q3 with my license and it resolved the problem. Thanks again!
(411 Views)
