LabVIEW 2025 Q1 crashes
Against my better judgement I have been forced to use LabVIEW 2025 on Windows 11.
Daily now I am having LabVIEW crash, IE completely close all open windows with no error or warning message. With that amazing debug info/s and some knowledgebase articles I found the last crash file attached.
Some of the lines near the end mention a vision actor vi and a number of breakpoints.
If anyone has any thoughts for troubleshooting this further, they would be appreciated.
(588 Views)
One thing in the list there is a couple entries for "mgcore", which is a LabVIEW memory management DLL.
See this thread where someone else did some DLL swapping after I pointed them to a LavaG post about that DLL:
https://forums.ni.com/t5/LabVIEW/Labview-crash-0xc0000005-mgcore-SH-26-1-dll/m-p/4433738#M1308042
They marked it as solved and haven't been back so it looks like it worked for them, but they did have a different error than you did.
You can give that a try and see if it helps.
(547 Views)
Your log shows you using 2025 Q1 Patch 1. There is a Patch 2 released, you could update and see if you get the same kind of crashes.
(537 Views)
