LabVIEW 2025 short cut Ctrl+, - not work
I try to use short cut key Ctrl + and Ctrl- to change the font size on label but it does't work. I try with LabVIEW 2021 is OK but not with LabVIEW 2025. I don't know if I use wrong key or some thing change in new revision of 2025.
(510 Views)
Accepted by topic author HARRY_D
This change happened in LabVIEW 2023Q3 with the introduction of Zoom. Ctrl+ and Ctrl- were changed to affect the zoom, matching the industry standard. The font can be adjusted with Ctrl+< and Ctrl+>. Do note that this is Ctrl+Shift+, and Ctrl+Shift+., which was a common misconception.
More details from the beta forum: https://forums.ni.com/t5/LabVIEW-Public-Beta-Program-in/New-Feature-Diagram-Zoom/td-p/4297781
(507 Views)
