Spreadsheet function format problems
Hi everyone!
I'm having an issue with the "Spreadsheet String to Array" function in LabVIEW. The input is a text file containing IMU data, but the output values are not in the floating-point format I expected.
Could someone help me figure out what I'm doing wrong? Thanks in advance!
(1,054 Views)
Accepted by topic author dstoyanov5
H dstoyanov,
Because your computer is set to use a comma as decimal separator, but the file is using a point instead!
Read the help for those format codes to adjust the format string as needed…
(1,035 Views)
Set the Format Specifier to %.;%f to force it to use decimal point.
Qestit Systems
Certified-LabVIEW-Developer
(1,024 Views)
