LabVIEW 8.2 - Custom Probe mystery behavior
Hi:
I recently updated code built in v7.1 to v8.2.  In one section, I have a simple wire that contains I16 data array.  When I put a probe on the wire, the probe shows the data as it should.  When I select a custom probe via 'custom probe,' 'controls,' 'waveform graph.', the waveform graph probe remains grayed and does not show the data.  Had no problem with this in v7.1.
Message 1 of 8
(5,486 Views)
Interesting...
I can confirm that it does not work for integer probes (tried I16, I32, U32). It  works if the data is set to DBL.
(Downconverted, all data types work fine in LabVIEW 8.0.)
My vote is that this is a bug, and a pretty annoying one.
Message Edited by altenbach on 08-29-2006 08:43 AM
Message 2 of 8
(5,474 Views)
Hi Don,
I hope you're doing well.  This was reported to R&D (# 40THMI99) for further investigation.  It looks like the waveform graph custom probe does not have the same behavior with the DBL data type.  A couple of work-arounds may be to create a subVI to behave as a probe instead, or you can add another waveform graph to your VIs front panel.  We definitely appreciate the feedback.  Have a great day!
Thaison V
Message 3 of 8
(5,427 Views)
Did this get fixed in LabVIEW 8.2.1 and if not, why?
Don
Message 4 of 8
(5,254 Views)
Still not working in 8.2.1. Just tried it.
pat
Message 5 of 8
(5,244 Views)
Fixed yet in v8.5??
Don
Message 6 of 8
(5,075 Views)
For a list of bug fixes in LabVIEW 8.5, check the LabVIEW 8.5 Bug Fixes page.
reggier
Message 7 of 8
(5,054 Views)
Just tried in 8.5. Still doesn't work.
Message 8 of 8
(5,038 Views)
