I try to read back the uController's register using Aardvark I2C adaptor with LV 8.2. I have no problem to read back one register. But the read back is unstable when I tried read more than one registers (Sometime bounce between 0 and real value). Please see the attached VI.
Also, is it a way to read/write all 256 registers at once?
I just bought the NI-8451 to give it a try, but it is not working. I'm trying to read the register 0x32 and 0x95, it alway read back 0 and no error massager come out.
Have you tried using any of the I2C examples? You can find them in the example finder, by opening Hardware Input and Output>>I2C and SPI. Do the examples return the expected data?
