LabVIEW 8.2 Quits Unexpectedly when launching on Mac OS X 10.9.4
LabVIEW 8.2 had been working with my MacBook Pro.  However, since upgrading to OS X 10.9.4, it no longer launches successfully. I have tried reinstalling LabVIEW.  However, LabVIEW never completes the inital start-up.  Here is the beginning of the crash message:
Process: LabVIEW [756]
Path: /Applications/National Instruments/*/LabVIEW.app/Contents/MacOS/LabVIEW
Identifier: com.ni.labview
Version: 8.2 (8.2)
Code Type: X86 (Native)
Parent Process: launchd [176]
Responsible: LabVIEW [756]
User ID: 501
Date/Time: 2014-07-20 10:50:39.422 -0400
OS Version: Mac OS X 10.9.4 (13E28)
Report Version: 11
Anonymous UUID: 2E840009-1E1C-33A1-4F52-F753554D1A6C
Sleep/Wake UUID: 52518E76-21B1-4CB9-B83A-A4BFD75F8178
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x9aee991c _vsnprintf + 51
1 libsystem_c.dylib 0x9aee9cc5 vsnprintf_l + 61
2 libsystem_c.dylib 0x9aedb2bc snprintf + 80
3 com.ni.labview 0x0119466c void (anonymous namespace)::_ToDebugStream<unsigned long>(DebugStream&, char const*, unsigned long const&) + 52
4 com.ni.labview 0x00e49dc6 ToDebugStream(DebugStream&, unsigned long) + 32
5 com.ni.labview 0x005d76d9 EventOracle::DestroyQueueObject(unsigned long, long) + 89
6 com.ni.labview 0x005ce66c EventNodeRTInit + 728
7 ??? 0x02fbe269 0 + 50061929
Message 1 of 8
(3,709 Views)
V8.2 is rather elderly. Are you sure it is still supported? Did anything unusual happen during the OS update process?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,701 Views)
As far as I can tell, noting out of the ordinary happened during installation of the O/S upgrade.  V. 8.2 was working well under the previous O/S version and there were no errors or warnings during the re-installation after the problem occurred.
Message 3 of 8
(3,671 Views)
 It is possible that the Preferences file has been corrupted. Try deleting the preferences file.
  1. Browse to [Home]/Library/Preferences where [Home] is your home directory.
  2. Delete the LabVIEW.app 8.2 Preferences file
  3. Restart LabVIEW.
Restarting LabVIEW will automatically generate the preferences file with the default settings.
Jon F.
Technical Support Engineer
Message 4 of 8
(3,641 Views)
Thanks for the suggestion but there is no LabVIEW preferences file in the indicated folder on my Mac.  I even did a deletion of the current installation and a complete re-install and the same problem recurrs.  It happens after the "initializing plug-ins" step appears on the splash screen.
Steve
Message 5 of 8
(3,598 Views)
According to this document LV 8.2 was barely compatible with OS X 10.4 and 10.5.
I suspect that you have reached somehwat beyond the place where LV 8.2 can be used on the Mac. I have run it on OS X 10.8.5, but very little. It was already installed under an older OS version, so I do not know if the installer would run. I presume you have worked around Apple's "security" against software not found at the App Store.
Here is a link for finding the preferences file.
Lynn
Message 6 of 8
(3,592 Views)
I did remove the file but it made no difference.
Message 7 of 8
(3,578 Views)
I also tried using the "control open" sequence for opening the application and that made no difference.
Message 8 of 8
(3,573 Views)
