LabVIEW 64-bit crashes upon startup but LabVIEW 32-bit works fine.
Recently had to uninstall and reinstall both LabVIEW 32 and 64-bit versions because the network administrator is dumb.  Now 32-bit works fine but the 64-bit version immediately crashes upon opening.  Getting the following Labview Crash: Exception: Unknown (0xC06D007E) at EIP=0x000007FEFCE1940D.  We're running LabVIEW 2012 on Windows 7 64 bit system.
(2,669 Views)
Did you try to repair the 64-bit version? Was it working previously fine?
(2,621 Views)
