Thorlabs SC10 shutter controller on labview
I need help integrating Thorlabs SC10 shutter controller into my existing LV programs for imaging applications.
Basically, I need to open shutter, do some measurements with Andor Neo sCMOS device then close shutter, repeat same measurements, move to a new point and repeat. I have inserted the suppallet of the Andor Neo sCMOS into the LV, but I dot know how to insert the suppallet of the shutter controller into LV even though there is a llb file on the setup file of SC10 shutter controller. Could please help me.
thanks
salihah
(3,226 Views)
Hi Salihah,
   You can place the .llb file in the user.lib directory inside your LV install directory. You then need to restart LV and it should appear in the user libraries sub pallete. If you don't need to access the drivers that often, then you can right click on the block diagram and choose select a vi from the context menu, browse to the .llb, which opens to reveal the drivers. You can open the .llb through the file manager, drag a driver vi onto the block diagram.
-Gabe
(3,193 Views)
