LabVIEW 8.6 improperly handles Shift+Right Click
To my knowledge, this bug is not yet fixed in the LabVIEW 2009 beta.  I'm not sure if it will be fixed in the release of 2009 or not.
Message 11 of 22
(1,705 Views)
Is this really that difficult of a bug to fix, or is it just not considered high priority?  It seems to me somebody forgot to check for the shift key when you right-click on a control.  I assumed it's a result of the changes for supporting setting properties for multiple objects.  This is a really, really annoying bug I run into countless times a day.
Message 12 of 22
(1,699 Views)
I'd guess that is the case.
Ben
Message 13 of 22
(1,682 Views)
Is there a work around?  Can the labview run menu be edited to allow a ctrl-key to bring up the tools palette?  I notice there is no curent method except show tools from the menu or shift-rtclick which nolonger works.  I just moved to 8.6 from 8.51 and no that I will NOT change to the auto-tool.  Using shift click and tabbing as second nature.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 14 of 22
(1,676 Views)
That's funny. I am NOT a user of the autotool, and I hadn't noticed this bug yet. I tab through the tools and just don't need to bring up the tool palette very often. Pretty much the only time I bring up the palette is when I am turning the autotool off when I sit down at someone else's computer. What tool is it that you are manually switching to that you can't access through tabbing (that you use 500 times per day)?
just curious.
Chris
Message 15 of 22
(1,675 Views)
falkpl wrote:
Is there a work around?  ...
Move to a blank part of the screen.
"tabbing to the tool I need,
Tabbing, I love the speed,
(Think Grateful Dead "Trucking" Smiley Tongue )
Message 16 of 22
(1,677 Views)
just curious.
Chris
Some of us just use shift and select instead of tabbing through the tools.
Message 17 of 22
(1,647 Views)
It's my understanding that there was a pretty hefty change to the codebase to support some other functionality, and this bug was introduced by that change.  So it's not a simple fix, and the solution also isn't as simple as backing out that change.  Also, I have pointed the owner of that code, and one of the LabVIEW 2009 project managers, to this thread.  So the right people are aware of this particular pain point, and we are investigating whether or not a fix can go into LabVIEW 2009.
Message 18 of 22
(1,627 Views)
Maybe the Get Color/Pick Color tool (so as to color cases/loops), while you are on the BD... ?
- Partha ( CLD until Oct 2027 🙂 )
Message 19 of 22
(1,419 Views)
I just saw this reply come up so I reread the thread to remind myself of the issue. I still have not noticed the behavior in my normal workflow, but I just tried it in 8.6.1 and 2009 to see. It looks like it's been fixed. I really wasn't picking on anyone who uses LV differently then I do (I figured I was in the minority by not using the Autotool anyway). I just think it's curious to discover that people have such different ingrained ways of working in LV. To some people, this bug was egregious and noticeable within 5minutes of sitting down.. but to me, I didn't notice it for the whole year I was using 8.6.1. I think it is awesome that LV is a tool that allows that sort of flexibility.
Chris
Message 20 of 22
(1,403 Views)
