LabVIEW + Arduino Nano "not in sync" firmware error
Hi, I'm using LabVIEW 2019 with MakerHub and an Arduino Nano.  I'm trying to upload firmware using the firmware wizard, however the process completes and the log shows:
avrdude_ard.exe: Version 6.0.1, compiled on Mar 30 2015 at 14:56:06
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "avrdude_ard.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude_ard.exe: stk500_recv(): programmer is not responding
avrdude_ard.exe: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe2
avrdude_ard.exe: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe2
avrdude_ard.exe done. Thank you.
Seems like the wizard can't connect to the Arduino.  I tried running the firmware wizard again, with the device identified as an Arduino Uno, and the log indicates the process succeeded.  Though I can't seem to send SPI commands properly, which is a separate issue, though could be related to it not having correct device information.
Any advice as to how to get the proper firmware uploaded to the Nano?  Thanks!
Message 1 of 1
(2,042 Views)
