Labview NXG Text Button Show Text -- only one text can be displayed
Just want to share and Confirm this...
I am using Labview NXG 5.0 and I just realized that only one text can be showed on a Text Button, no matter it is in True or False state.
See below example for Text button, only one show text can be set, no matter it is in true or false state.
If I need a switch button, and I want to show different text on the button for True / False state. I have to use a LED button, and change to a control type, and then customize it to display different show text. It is not as convenient as LabVIEW.
(2,465 Views)
Some workaround, but you found one.  I hope they implement it in teh future.
Bill
CLD
(Mid-Level minion.)
(2,436 Views)
