LabVIEW CAN FD READ
When I set the parameters to monitor the product CAN communication readback through the X-NET Busmonitor tool, it works, but when I use LABVIEW VI to monitor it, it does not read any Farme.
(2,038 Views)
Accepted by topic author White.Wang
This question is best to be posted on the Automotive and Embedded Networks board.
Back to your question, in your LabVIEW program, use :can_fd_brs: instead of the default :memory:
How to Create CAN FD Dynamic Database in Memory
https://tmesystems.net/
(2,035 Views)
Thank you very much, your answer has helped me to solve the problem. Thanks again for your help!
(2,026 Views)
