profile performance and memory dialog
"Test single stage.vi" calls single Task.vi of Zaber library using Start Async Call Node.
Profile performance and memory dialog shows:
- 5 (!!!) Task.vi and 4 looks as Task.vi:Instance:***
- 5 (!!!) "Test single stave.vi": one as "Test single stave.vi", two as "Test single stave.vi:Instance:***" and two "[Test single stave.vi]"
Why?
Message 1 of 13
(3,729 Views)
Hi Vasilich,
are those reentrant VIs?
Message 2 of 13
(3,685 Views)
Task.vi is reentrant VI.
Message 3 of 13
(3,680 Views)
Ohh ... Test single stage. VI is also reentrant vi. It is top level vi and there isn't reason to make it as reentrant. I will place new Profile dialog later.
Message 4 of 13
(3,678 Views)
Test signal stage.vi is non-reentrant. No changes/
Message 5 of 13
(3,658 Views)
What's the question?
~ Helping pave the path to long-term living and thriving in space. ~
Message 6 of 13
(3,603 Views)
Why are there 5 lines "Test single stage.vi" and "Task.vi" instead of one line?
Message 7 of 13
(3,583 Views)
Hi Vasilich,
Now there's time to attach some code so we can examine the problem.
(It's quite hard to analyze from looking at some images of the profiling dialog…)
Message 8 of 13
(3,571 Views)
I'm assuming Task is Preallocated reentrant. If so, it'll create an instance for each placed in the code (or a few in a parallell loop). (qualified guess)
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 13
(3,557 Views)
Your profile window clearly proves otherwise! It may not be the VI itself set to be reentrant but the way you launch it in your program.
As others said: It's time to attach some code. Debugging images is always a pitta.
Rolf Kalbermatter  My Blog
Message 10 of 13
(3,549 Views)
