LabVIEW CPU Stress Tester
Anybody have a CPU stress tester program writen in LabVIEW that will floor all logical CPUs to 100%?  Thought this would be an easy task but I think the compiler optimizations are so good now-a-days that the best I can do is get a sustained 65% when I use a For-loop with iteration parallelism set to the "# of logical cores".
(6,323 Views)
Accepted by topic author SeanDonner
Hi Sean,
this little VI puts my i7-4700 to 96-99% at 130% turbo boost:
(Parallelism to 8 cores…)
You know there are special tools to keep the CPU as busy as it can? "Burn-in tests" will use most/all parts of a modern CPU (like SSEx,MMX,FPU,…).
That little VI above will probably only use some FPU commands…
(6,310 Views)
Why not place several tight while loops (e.g. 😎 on the diagram instead of using a single parallel loop.
Also note that you only have 4 actual cores and it might not be possible to keep all 8 virtual cores busy due to contention.
(I was able to keep 32 virtual cores (16 real cores) busy 100%, see the bottom graph here)
(6,278 Views)
Thanks, I creating a fixed random array of similar lengh then doing a linear search on it with a randomly generated number on each iteration thinking that would do it; this is much simpler and does get me to 98% on average.
(6,260 Views)
Prime95 is the most commonly used program for stress testing CPUs (e.g. by overclockers) if you're not particularly looking for a LabVIEW solution.
(blog)
(6,221 Views)
I'm familiar with Prime95 and the main reason I wanted a LabVIEW solution is because I don't have to jump through any of our corporate bureaucracy to get software approved for installation if I write it myself.
(6,182 Views)
