LabVIEW Code for Rotation and Z Stage Positioners
In our lab, we have a 8MR151 - Motorized Rotation Stage and a 8MVT70-13 - Motorized Z Stage combined. The current two codes both work for z movement (vertical). What I need to fix is one of the codes so that one can work for rotational movement not vertical. I am new to LabVIEW and I need help! Thank you!
(3,479 Views)
Hi bubble123,
Have you tried implementing the same protocol for the Z movement to the rotational movement? What about it hasn't worked? Also, where in the code actually accesses the Z movement? Trying to figure out which VI does what.
Aulia V.
(3,397 Views)
