Remote Data Collection
My research group needs to collect data including temperature, humidity, and windspeed, but we need to do it remotely (so the computer cannot be at the actual site). Does anyone know whether LabVIEW has equiptment for that or how to start on this? Thank you so much.
(3,780 Views)
Hi molocule,
LabVIEW is a programming language, so it can be used to create programs which will read data from remote devices…
What you need is a remote device able to measure your data and with a proper ("easy to use") interface so you can read the data with LabVIEW!
I use some devices to get air temperature, pressure and humidity with a nice (and easy) TCP/IP interface…
(3,767 Views)
Yes LabVIEW can do that.
The important question is: What kind of interface does your weather station have and how are you going to remotely access it?
Consider using a nearby National Weather Service site and poling their web interface for the data like this.
=== Engineer Ambiguously ===
(3,735 Views)
