LabVIEW DSC: (Hex 0x80070057) One or more arguments are invalid.
I get this error when my dsc server loads and the dscengine is shutdown. Can anyone tell me what this error means
(4,009 Views)
If you log some historical data to a Citadel database to a folder on a secure file system (NTFS), you might want to check the Knowledgebase article linked below.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/4263da141111ea2086256a1b00821611?OpenDocument
If not, could you give more information about your application,
- Which version of LabVIEW DSC are you using?
- Are you logging data?
- Does it happen all the time or it only happens when you run a specific DSC applications?
Remzi A.
(4,009 Views)
