LabVIEW DSC modbus I/O server 32-bit floating point data
I'm using LabVIEW 2021 SP1 and the DSC (datalogging and supervisory control) module.
I've created an I/O server using the DSC's Modbus Library and I'm using Shared Variables to communicate with a PLC via modbus TCP.
No issues for boolean and integer data types. But the floating point data type is confusing.
There are two address ranges which have the 32-bit floating point data type ("single" "SGL" in LV). But they are 1D Arrays of SGL.
AF300001L1 - AF365534L1 is Read only, and AF400001L1 - AF465534L1 is Read and Write.
It's not clear how these addresses correspond to addresses of modbus variables on the PLC side. I have created bound shared variables for these ranges, but the addresses don't match anything on the PLC side.
How do I make this work for floating point variables?
Message 1 of 1
(203 Views)
