LabVIEW Electrical Power Toolkit 2023
Hi. Is it possible to work with this VI if not using any of the listed NI hardware:
  • CompactRIO platform
  • CompactDAQ system
  • NI PXI platform
My plan is to use a DSP to stream current/voltage data to LabVIEW for Power Quality Analysis.
The LabVIEW Electrical Power Toolkit 2023 Q3 Readme - NI product page is not explicit in stating NI DAQ Hardware must be used.
Thanks.
(565 Views)
Because it is a data analysis library and does not interface with any hardware. The waveform data can come from anywhere but typically from a NI-DAQmx device.
See LabVIEW Electrical Power Toolkit API Reference
https://tmesystems.net/
(515 Views)
