LabVIEW: End of file encountered. the file 'xxxx.vi' could not be loaded
My laptop froze and so my vi wasn't closed properly. And now when I try to open it, I get the message: LabVIEW: End of file encountered. the file 'xxxx.vi' could not be loaded.
So I can't open the vi...
Is there a way to solve this problem or recover the vi?
I attached the vi so maybe you could try and see if it does open at your pc.
Thank you!
Ruben
(7,937 Views)
Sorry, failed for me.
Some suggestions to mitigate such problems in the future (especially important if you are developing "serious" LabVIEW code, as opposed to doing small exercises as a student):
  • Use a Version Control System.  Many LabVIEW developers use Subversion, with several developers releasing Tortoise SVN toolkits that "hook" into LabVIEW.  An admired LabVIEW Developer/Speaker refers to this practice as using a "Time Machine".
  • Keep all VIs small (in screen space, which translates to program size).  Use lots of sub-VIs.  With 100 sub-VIs in a project, you'll only lose a small percentage of your effort if something like this happens again.
Bob Schor
(7,916 Views)
