system exec returning error
Reaching out to the community once again!
I am attempting to assign a static IP and Subnet Mask to my network adapter so that I can communicate with a device under test. However when I pass the data to the System Exec it returns this error no matter what I change the Mask to. Also if I add a Gateway IP after the Mask it will change the error to 192.168.?.? is not an acceptable value for gateway IP.
Has anyone run into any similar errors?
Greg
(3,163 Views)
Have you tried running that command in a Command Prompt window ?????
This is NOT a LabVIEW question!
(3,150 Views)
