LabVIEW Equivilant to excel functions?
Hi, I'm trying to translate some equations done in Excel into LabVIEW.
Does anyone know what the LabVIEW equivilant is for the Excel command:
ROUND(x,0)
Also, what is the equivilant for
INT(x)
Many thanks, Alec
Message 1 of 17
(7,143 Views)
Here you go:
The top 3 functions, from left to right:
1) Round to nearest
2) Round down
3) Round up
The palette below shows all types of numeric type conversions.
To convert to int, you can do I64, I32, I16, or I8
Message Edited by Cory K on 08-13-2009 10:13 AM
Cory K
Message 2 of 17
(7,135 Views)
 I am aware these functions, but I don't think one of those works in exactly the same way as ROUND(x,0) do they.. or do they?
Message 3 of 17
(7,127 Views)
To be honest, I'm not sure because I dont use excel much.
What exactly does ROUND(x,0) do in excel?
Once I know the functionality, I can point you to a better function.
Cory K
Message 4 of 17
(7,125 Views)
Round Numbers
The ROUND Function will round numbers to a specified number of digits. If the number of digits is negative, it will round to the left of the decimal point. If zero it will round to the nearest Integer (whole number).
=ROUND(1.5,0) will result in a value of 2
=ROUND(1.4,0) will result in a value of 1
Round Numbers Up
The ROUNDUP function will round numbers up, away from zero.
=ROUNDUP(1.4,0) will result in a value of 2
Round Numbers Down
The ROUNDDOWN function will round numbers down, toward zero.
=ROUNDDOWN(1.6,0) will result in a value of 1
INT (although less flexible) can also be used. =INT(1.6) will also result in 1
Message 5 of 17
(7,119 Views)
If you are going to input the second parameter as 0 : ROUND(x,0)
Then you will want to use round to nearest.
The cutoff with be .5
An odd number will round up, and an even number will round down.
Ex:
13.5 --> 14
16.5 --> 16
11.3 --> 11
11.8 --> 12
Cory K
Message 6 of 17
(7,112 Views)
The Rounds in LabVIEW do not have decimal place inputs, so are equivalent to the ROUND, ROUNDUP, and ROUNDDOWN with the second parameter set to 0.  ROUND is Round to Nearest.  IF you want decimal places, you will have to do your own coding to shift the decimal places and do rounding.
Message 7 of 17
(7,111 Views)
Accepted by alecjcook
So Round(x,d) will impement as round.PNG I missed the negate of d on the first shot
Message Edited by Jeff Bohrer on 08-13-2009 11:01 AM
Message 8 of 17
(7,095 Views)
Wow, nice job Jeff
Cory K
Message 9 of 17
(7,089 Views)
Thanks Cory.  pretty basic
Message 10 of 17
(7,078 Views)
