LabVIEW FPGA Array operations
If case structure outputs same size of array from both the cases, there is no issue. Issue is when the sizes are different.
Message 11 of 16
(1,304 Views)
Hi scsp,
as has been said many times before: the FPGA can only handle fixed size arrays and you CANNOT mix two different sized arrays on one case structure tunnel!!! There is no issue...
Message 12 of 16
(1,303 Views)
Okay , agreed. Creating different VI's for different cases is the only alternative is it?
For the other question of mine regarding copying the array elements to a constant array on FPGA Target, entering individual elements is the solution?
Message 13 of 16
(1,285 Views)
If you are in or can sign up for the 2013 Beta, the LabVIEW FPGA Module now supports compile-time resolution of array sizes which means you can write VIs that accept variable-size arrays and as long as the compiler can infer fixed-sizes for the arrays your design will be synthesizable.
Message 14 of 16
(1,272 Views)
Wow really?  Is that public knowledge?  Because I thought those in the beta couldn't talk about its features.
Message 15 of 16
(1,258 Views)
Well, this somewhat related to several ideas from the idea exchange, so in general we would have marked the idea as "In Beta" anyway. So, if you don't tell anyone, I won't : )
Message 16 of 16
(1,255 Views)
