LabVIEW FPGA Error -61499
I am new to LabVIEW and FPGA.
I set up a Linux Compile Worker to make comipling faster.
I installed a CentOS 7.3, with the LabVIEW 2014 FPGA Xilinx Module.
But when I try to compile the VI after a few seconds the following dialog with the error pops up:
(5,274 Views)
As a sanity check, are you able to compile an example FPGA project?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(5,235 Views)
no that doesn't work. - Same issue.
My VI will be compiled correct on my local PC.
But not on the new set up Linux machine.
Regards
(5,192 Views)
Not sure what else to suggest other than repairing or reinstalling LabVIEW, LabVIEW FPGA, and the Xilinx compile tools.
Is this your first time using LabVIEW FPGA?
ALE Consultants
(5,185 Views)
On Linux I only installed the XILINX ISE modules. Nothing else. I will try to repair the installation there.
I am new to LabVIEW and FPGA and my team leader is on vacation at the moment.
He is well known on LabVIEW and FPGA. But he doesn't know something about compiling the FPGA on a remote Compile Worker with Linux.
Compiling a VI on a remote Windows PC which is Compile Server and Compile Worker in one, works fine...
(5,173 Views)
