LabVIEW FPGM cRIO NI 9853 programming issue
Hi, when I create new FPGA project on cRIO-9022 I have the following issue:
-FPGA I/O module when inserted into block diagram shows as on screenshot.
My question is, what am I doing wrong/ what configuration has to be done.
My PC configuration:
Win 7,
LV2016, Real-Time Module, FPGA Module and NI-cRIO9022 drivers installed.
Hardware is configurated and seen by NI MAX.
(3,053 Views)
Hi Partial,
AFAIK the NI9853 needs to be programmed in the FPGA. It will not work in the RT target…
Atleast that's what I do since years:
(3,047 Views)
Yeah, I missed target device, I should create VI on FPGA module as you said. Now it is working fine. Thanks for reply.
Cheers. 😉
(3,023 Views)
