LabVIEW: File is not a resource file. The file is not a valid LabVIEW file
@naiaracastrillo wrote:
Do you have idea how could it be? I have no idea how I have overwriten that or how I have corrupted the file.... It's for not doing any more
We can only guess. It is possible that you were running a different program and when a file dialog appeared to save the data, you selected the VI. Of course if could also be a general file system corruption, so try to check the drive for errors. Was this a conventional HD or an SSD? Did you lose power while the computer was running? Also scan your computer for malware, for example.
My first guess is still PEBKAC, however. Are other users use the same account?
Message 31 of 34
(1,696 Views)
hi could u help me restore this file .
thanks
Message 32 of 34
(1,660 Views)
Hi Arbo,
how should we?
You need to look up for an backup on your own - we cannot do that for you!
(Your file doesn't start with the typical VI RSRC header, so it looks like garbage. Is it encrypted by some unkown other software?)
Message 33 of 34
(1,657 Views)
hi
I have started restoring the old code of another person project , who leaved the company. and this file doing the problems.
the backups is another issue.
have a nice day.
Message 34 of 34
(1,652 Views)
