LabVIEW: File is not a resource file. The file is not a valid LabVIEW file
Hi Gerd,
Thanks for your reply.
I created backup up a month ago and many changes have been made from the backup data.
Is there any possibility to retrieve the data?
Message 21 of 34
(3,428 Views)
Hi CNRK,
probably NO. You may ask the NI support for help…
Atleast you should have learned by now to create backups more often. Maybe you should also learn to use SVN or GIT?
This is no offense, but just common sense. Some lose work of a day and go crazy about that, other lose work of a whole month…
Message 22 of 34
(3,426 Views)
HI Gerd,
Thanks for the info... I will do it from now on.
Message 23 of 34
(3,418 Views)
Hi Waldermar I have the same problem but it seems like that my file starts only with RSRC and not RSRC<LF>. Plus after correcting it I don't know how to open it again with labview...Could you help me please?
Message 24 of 34
(3,232 Views)
Not having a backup of your file?  Yikes.  TINKERING with a file without at least making a copy of it first... not sure what to say about that.
Bill
CLD
(Mid-Level minion.)
Message 25 of 34
(3,223 Views)
I ve the same problem, I am trying to open my vi file and appears:
"LabView: File is not a resource file.
The file 'cliente v3.vi' could not be loaded.
I opened it with UltraEdit but there is no any "RSRC<LF>" to be replaced by "RSRC<CR><LF>".
I dont know what can I do.
I have checked  \Documents\LabVIEW Data\LVAutoSave but I dont have any copy.
I have LabView 2013 and Windows10
I attach my file 'Cliente v3.vi'
Thanks for your help... I have the presentation tomorrow... and now I'm lost 😞
Message 26 of 34
(3,184 Views)
Lesson learned, I guess: ALWAYS use some kind of versioning software (and commit often) so you have a recent version to fall back on.  😞
Bill
CLD
(Mid-Level minion.)
Message 27 of 34
(3,182 Views)
You overwrote the beginning of the file with formatted numeric data. the file is irreversibly lost.
Message 28 of 34
(3,172 Views)
Thank you for your answer.
Do you have idea how could it be? I have no idea how I have overwriten that or how I have corrupted the file.... It's for not doing any more
Thx
Message 29 of 34
(3,168 Views)
Thx
Maybe a path was incorrectly concatenated, like the path was relative to the VI and the name of the VI was supposed to be replaced with the name of the file to write.  But it wasn't, so the VI, itself, was overwritten.  😞
Bill
CLD
(Mid-Level minion.)
Message 30 of 34
(3,164 Views)
