LabVIEW Front panel : bottom part not updating at runtime
Hi Thomas,
I am also seeing an issue (not sure if it is similar to yours) where my FrontPanel does not appear fully until I click on any of the location where the buttons are supposed to be. This triggers a value change & the front panel appears. Can you please provide the screenshot of the solution which cleared your issue?
Priyadarsini S
Message 11 of 13
(1,064 Views)
Never got a fully working solutions.
I've had this issue multiple times.
Quickest way to solve is by going to block diagram, select all - copy.
Create new vi - go to block diagram - paste.
Now only clean up front panel and you have a repaired version of your VI.
Message 12 of 13
(1,053 Views)
Sure, Thomas, will try your suggestion. Thank you!
Message 13 of 13
(1,029 Views)
