LabVIEW GUI Bug? - Try and post yours as well
While answering for a question I was playing with the Event structure and I saw the Find Control option when I right click that structure. Here is what I did after that
Selected the Find Control and it took me to the front panel showing a big box kind of selection. Out of curiosity I pressed down button along with shift and also up button I got a wiered screen and I have attached it here. I am using LabVIEW 2009 so is it happening in this version or is it still there in 2012 and other versions?. Who ever has higher version can do the same step and post what you got.
(3,031 Views)
The same happens in 2011.0. This is moving the pane of front panel out of the window somehow. When I resize window, everything going back to normal.
Using horizontal splitter I've even managed to add some "cinematic" feel of the front panel 😄
(3,000 Views)
