Problem with using Labview to control SPEX 1680B spectrometer
Dear all,
I just recieved a SPEX 1680B double spectrometer(which is a quite old machine with a RS232 interface on its body) from a retiring professor. I want to put it into use while I know little about how to make it listen to me. All I know is I am supposed to utilize Labivew(with VISA) to send code to it and receive the results. Could anyone please tell me which part of Labview should I use and what exactly should I do(procedures with steps are preferred). I am freshman on it, so please don't laugh at me:p~~Thank you in advance!Your every effort will be highly appreciated.
Azure Li
(3,005 Views)
No laughung here.... Welcome to the forum.
If you search for SPEX 270M You'll find a driver converted from the old serial mode to the more up-to-date VISA for the SPEX 270M Spectrometer, maybe this could be a starting point for you.
Good luck
Shane.
(3,001 Views)
Thank you, Shane! I'll try it right away. Also thank you for your warm welcome!
(2,998 Views)
