LabVIEW : How to export a 1D array faster to a .xlsx file
Hello everyone,
I'm currently using LabVIEW (2020 SP1) to automate testing of electronic boards and laser diodes. At the end of each test bench, a large amount of data needs to be exported into a .xlsx file.
To do this, I load an Excel template, fill it in with the new data, and then save a copy locally.
The issue I'm facing is that the export process is very slow, it takes approximately 15 minutes to complete.
I can't share the full code here, but I can show the key parts.
Here’s how I create the .xlsx file:
And here's how I export most of the data :
This process is repeated multiple times throughout the export.
From what I can tell, the bottleneck seems to be this part:
As the 1D array that I'm trying to export contains around 300 values.
Has anyone encountered a similar issue or found a way to speed up Excel export in LabVIEW?
Any suggestions or best practices would be greatly appreciated!
Kind regards,
Raphaël
Message 1 of 9
(469 Views)
Accepted by topic author rpbrn
Instead of writing individual cell to the Excel template, try build a 2-D array in LabVIEW, write everything to the template in one call.
George Zou
Message 2 of 9
(455 Views)
Hello George,
I thought about doing so. But I only have 1 column of useful data.
Is it possible to create a 2D array with a "void" column ?
Raphaël
Message 3 of 9
(443 Views)
If I remember correctly, write to a column need a 2-D array.  Use the Build Array function to convert a 1-D array to 2-D.
George Zou
Message 4 of 9
(435 Views)
I wasn’t able to convert my 1D array into a 2D array, but I managed to merge my 1D array with an existing 2D array and export the resulting 3D array all at once.
The export process is indeed much faster.
Raphaël
Message 5 of 9
(383 Views)
Hi Raphael,
Whatever you did you did it wrong!
There is no "merge array" function: what exactly did you try to implement?
It should be as easy as this:
Message 6 of 9
(373 Views)
Hello GerdW,
You're right, it turns out I didn't fully understand how the "build array" function works with 1D arrays!
Here's what I did :
Perhaps "merge" wasn't the right word ? If so, sorry, english isn't my first language.
What I meant was that I used the "build array" function to combine three 1D arrays into one.
Kind regards,
Raphaël
Message 7 of 9
(359 Views)
Hi Raphael,
Which LabVIEW language version do you use? There context help shows the English name of each function!
Building 3 1D arrays results in a 2D array: the context help shows also the datatype of each wire the mouse pointer hovers over!
Like this:
Message 8 of 9
(352 Views)
Oh you're right, the context help window does show the english name of the function.
Thanks again for the explanations GerdW !
Kind regards,
Raphaël
Message 9 of 9
(343 Views)
