LabVIEW Modbus
I need to communicate with an instrument with LabVIEW through MODBUS using RS-232.
The instrument is the slave and the computer is the master.
I'm using the NI MODBUS Library
Question: when creating a MODBUS instance in labview should it be NEW Serial Master or New Serial Slave ?
(1,378 Views)
The computer should be a New Serial Master since you are simulating a master on your computer to communicate with the slave instrument.
(1,370 Views)
