Syringe pump issues regarding wiring of parameters
Hi there,
I'm having some trouble with my syringe pump. I've attached the code I've been working on, and I'm wondering if someone can help me figure out how to make the parameters work. The buttons for start, pause, stop, and reset are working fine with channels one and two, but none of the parameters I've entered seem to be sending a message to the pump. If someone can help me get at least the rate and volume working, it would be great.
so, I kind figured out that the parameters are linked with the option to use the syringe pump in steps. I don't want to use steps. what I'm looking to do is use the parameters without having to use the steps' function. I have no clue how to delete and wire again all the script if most of the parameter section is linked to the steps function.
Any help would be greatly appreciated.
(813 Views)
Please do a "save for previous (2020 or below)" before attaching. I cannot see your code.
(781 Views)
Attached is a 2019 and 2020 version
(776 Views)
